Photography and Videography Tips, techniques and equipment for taking great photographs and videos. Come here for advice and critique on your photos and videos. To show off your S2000 go to The Gallery
Camera lenses
Old Apr 1, 2007 | 02:51 AM
san2000's Avatar
Default Camera lenses
Can anyone tell me what the difference in magnification achieved using the same lens ona dslr vs a slr are?
If any.....
Old Apr 1, 2007 | 03:07 AM
wampa's Avatar
depends on the camera.
My nikon there is about +7mm differnce.
Old Apr 1, 2007 | 03:21 AM
eSeM's Avatar
On the cheaper Canons it is 1.6x
Old Apr 1, 2007 | 10:32 AM
muttly's Avatar
The difference is due to the larger optic on an SLR camera ie 35mm format, than a DSLR, you get a larger zoom but will only "see" a certain amount as the image is larger than the chip face. if you have a DSLR camera with a through the lens viewfinder you will shoot what you see. The 1.6 time is the magnification from 35mm format to the chip size
Old Apr 1, 2007 | 02:48 PM
GT_2003's Avatar
basically, the image you get with a 50mm lens on a 1.6 crop Canon DSLR is the center of the frame on a 35mm camera with the same lens. People often multiply the lens focal length times the crop factor (the size of the digital sensor in relation ot a 35mm frame) to arrive at the 35mm equivalent. So a 50mm lens becomes similar to a 1.6 * 50mm = 80mm. IOW a 50mm becomes an 80mm equivalent when mounted on a 1.6 crop DSLR.
So depending on your sensor size, the difference in magnification is ~1.6, ~1.3 or in the case of a full-frame sensor, no difference.
