Photography and Videography Tips, techniques and equipment for taking great photographs and videos. Come here for advice and critique on your photos and videos. To show off your S2000 go to The Gallery
help len stuck
Old Oct 6, 2009 | 08:31 PM
s2k.'s Avatar
Default help len stuck
my friend accidently put a tiffen 52mm haze-1 onto my 18-55mm now it stuck i couldnt take it off.
Old Oct 7, 2009 | 03:00 AM
HonCBRf2's Avatar
is it the nikon 18-55mm lens, if so, it does take the 52mm filters, he probably just cranked it on tight.
Old Oct 7, 2009 | 03:31 AM
zzziippyyy's Avatar
Or cross threaded it. Try to find something that will give you more grip on it than keep trying to twist. It will breAk free eventually.
Old Oct 7, 2009 | 03:38 AM
AssassinJN's Avatar
Try some piping pliers or a bench mounted vice if you have one. If it wasn't the right size there's basically no way it could have mounted.
Old Oct 7, 2009 | 05:50 AM
AgS2K's Avatar
I've found putting a rubber band around the filter can give you the extra grip you need to work the filter loose.
Old Oct 7, 2009 | 07:16 AM
Penforhire's Avatar
Rubber band is a good idea. There is a special wrench or spanner made for stuck filters. If you use a pipe-wrench be very careful. Too easy to damage the filter or lens. Your local camera shop might help you out. You can try some temperature change, like putting it in the fridge, to see if the materials have different thermal expansion (could just make it tighter).
If you have a semi-soft rubber mat or cutting board you can see if pushing the filter flat against it give you some grip to turn.
Old Oct 7, 2009 | 10:32 AM
s2k.'s Avatar
yeah thanks guys the rubber really does work
Old Oct 7, 2009 | 02:48 PM
mzvyap2's Avatar
Old Oct 7, 2009 | 04:20 PM
AssassinJN's Avatar
Old Oct 7, 2009 | 05:24 PM
s2k.'s Avatar
