Photography and Videography Tips, techniques and equipment for taking great photographs and videos. Come here for advice and critique on your photos and videos. To show off your S2000 go to The Gallery
ISO Question
Old Feb 11, 2007 | 12:51 PM
robs04s2k's Avatar
Default ISO Question
I am just curious what you guys do in regards to ISO. Do you normally leave the camera on Auto or do you set it at a fixed value? Thanks.
Old Feb 11, 2007 | 01:23 PM
brushman's Avatar
fixed
Old Feb 11, 2007 | 01:36 PM
robs04s2k's Avatar
at 100?
Old Feb 11, 2007 | 05:55 PM
Norby's Avatar
I go as low as possible depending on the conditions
For example: During the day when its light i go as low as possible but in a dark church you still want to be as low as possible but not that low that you cant keep the camera steady...
Old Feb 11, 2007 | 05:59 PM
Liebernoodle's Avatar
I always leave the camera at 100 and only go up if I must due to not enough lighting for the aperture/shutterspeed that I need.
Old Feb 11, 2007 | 06:22 PM
wing's Avatar
100 works great for outdoor shots, but indoors 400+ IMO. I actually have my camera set to 800 99% of the time but it's a 5D and the noise level is ultra low.
Old Feb 11, 2007 | 06:29 PM
S2000Patrick's Avatar
Originally Posted by wing,Feb 11 2007, 07:22 PM
...I actually have my camera set to 800 99% of the time but it's a 5D and the noise level is ultra low.
That must be nice.
As someone mentioned earlier, I try to keep the ISO as low as possible for whatever the current shooting condtions are at the time.
I try hard not to go above 800 because of problems with noise.
Old Feb 11, 2007 | 06:58 PM
robs04s2k's Avatar
Ok so if I am shooting outside and I am going to have it fixed at 100. How do you guys know how to much to increase it as it gets darker? Is there a general rule of thumb?
Old Feb 11, 2007 | 07:04 PM
MyEeek's Avatar
Assuming that you have the camera set on an automatic shutter speed mode, then you should change to a higher ISO setting when the shutter is taking a longer time to take pictures. Or you can simply bump it up when you realize your pictures are blurry.
Old Feb 11, 2007 | 07:39 PM
NFRs2000NYC's Avatar
Always carry a little tripod with you (the 10" ones)....Then you can leave ISO at the minimum, and get the best shots possible, every single time.
