Photography and Videography Tips, techniques and equipment for taking great photographs and videos. Come here for advice and critique on your photos and videos. To show off your S2000 go to The Gallery
noise at iso 100 on 30d
Old Jul 18, 2007 | 04:39 AM
CarbonS2000's Avatar
Default noise at iso 100 on 30d
Im used a 17-85 is lens on my 30d at iso 100 for a 30 second exposure. Why am I still getting noise? you can see it in the water and the sky. I tried using noise reduction in the pull down in photoshop but still get the noise. Thanx for the help.
Old Jul 18, 2007 | 07:18 AM
iLuveketchup's Avatar
Did you raise the exposure, levels, curves, or any other setting?
Old Jul 18, 2007 | 07:25 AM
raised exposure 1/2 a stop
GT_2003's Avatar
30 second exposure is the culprit here, I believe. With high ISO's, the system is effectively turning up the gain, so you get more noise. With lower ISO's on long exposures, you are storing the sensor output over a longer period of time, so any noise at all gets captured. Consider it like taking all the noise from a hundred 100ISO images and putting it all into one.
You might experiment with shutter speeds to find a sweet spot with lower noise but enough exposure. Or use a larger aperture.
Old Jul 18, 2007 | 07:26 AM
Penforhire's Avatar
That 30 second exposure might just be too long for your sensor.
Old Jul 18, 2007 | 07:45 AM
jtpassat's Avatar
there is a "custom function" that allows for long exposure noise compensation. look it up on your manual.
Old Jul 18, 2007 | 07:57 AM
jtpassat's Avatar
ok.. waiting for lunch to come around here you go
http://www.kenrockwell.com/canon/30d...-functions.htm
Old Jul 18, 2007 | 08:18 AM
1/2 stop bump in exposure is a lot when capturing very low light levels. You're basically bumping pixels that aren't there.
Old Jul 18, 2007 | 08:25 AM
what if i bumped the iso to 500 and use a shorter exposure? would i get a better photo with less noise?
Old Jul 18, 2007 | 09:05 AM
jtpassat's Avatar
your best bet is to always use the lowest ISO possible, smallest aperture and long exposure AND the long exposure noise reduction function on the camera.
