Car "hunting over the road"
Hi Guys,
I tink I may have an issue with the S but I am too dumb to figure out what it might be.
The car seems to hunt around a little bit in the lane that I'm driving in. It is especially noticeable when cornering under a higher load, the car just plain does not feel planted at all. I will be driving along in a straight line and then have to make a correction out of nowhere. The car tracks stright 95% of the time but then I'll have to correct on a butter smooth road surface without any driver input.
So far, my tire pressure is equal all around
Checked all four wheels tonight for wheel bearing wobble and cannot detect anything
I haven't had an alignment done on the car in a long time. Do you think an alignment would fix me up? The car did not use to feel like this last summer and I didn't drive her in the winter at all.
I switched over to my autox tires last night expecting the wobble/hunting to dissapate as I was thinking the snow tires I had mounted were squirmy. Not the case, and I know my autox tires aren't squirmy on the road.
Maybe a bushing has too much wear and needs to be replaced, my S has 76KM on it so we are jsut broken in...thoughts?
I suggest you double check the rear wheel bearings. I had a similar issue previously. However, it kept getting worse and worse. Ultimately I had to replace not just the bearing, but the hub assembly and the stubby shaft off the axle too. Got expensive!
And since you autox, here's my suggestions for an alignment that works on the street and is OK for chasing cones:
Front camber: Max negative camber possible
Front Caster: Max possible without losing any front camber
Front Toe: 0 degrees, err on the side of toe out
Rear Camber -2.0 degrees
Rear Toe -0.20 degrees (toe in)
Perfect, thanks for all the help guys, I'll give Berts a shout tomorrow and see if I can get in there. Murray I am about to install the Sane sway bar would that change any of your suggestions on alignment specs?
Keep those specs -- no matter what sway bar or sway bar setting you run.
That little bit of rear toe in doesn't increase the tire wear in any way I can detect. However, it does make the car track much better on the highway -- even if you dial in a bit of front toe-out.
