Prairie Redliners Canadian Prairie Provinces. Alberta, Saskatchewan, Manitoba
Changing out soft top
Old Mar 31, 2011 | 07:23 AM
skool u's Avatar
Default Changing out soft top
Just seeing if anyone has changed out his own soft top here. I just ordered one with a glass window since mine is fading and the material is cracking all over the place. Any tips would be appreciated. I found the write up on here but it seems to cut off.
Old Mar 31, 2011 | 09:42 AM
saaboteur's Avatar
I did mine a couple years ago. I basically just followed the DIY from the forums here. Once you get started, it's pretty evident what you have to do. Did you buy the proper sized rivets and such yet? Also, if you have an AP1 with the plastic window, you will need to get some nylon straps to make sure the frame folds properly to not contact the glass window. That stuff is pretty straight forward too, but before you start the job, just be sure you have all the parts you need.
Old Mar 31, 2011 | 02:41 PM
~blacks2k~'s Avatar
I've been meaning to remove my soft top since I have a hard top installed, but after looking at the DIY it seems pretty involved so I have been putting it off. I may get around to doing it this summer though, looks like you have to pretty much take apart your whole interior to do it.
Old Apr 1, 2011 | 06:39 AM
Snow's Avatar
I am going to remove my soft top ( AGAIN) as I drop few of my Spoon Hardtop bolt inside and there is no way I can find them unless the softtop is out...anyway if you want to check it out let me know, I will start doing it tomorrow morning
Old Apr 6, 2011 | 04:28 PM
~blacks2k~'s Avatar
So, how did it go this time around? And how long did it take you?
Old Apr 7, 2011 | 09:56 AM
skool u's Avatar
When are you doing it? Where are you located?
Old Apr 10, 2011 | 10:41 PM
Snow's Avatar
My soft-top is already out as I said I will work on it last Saturday...anyway I finally found the bolt and now I will have to finish my roll cage install before I put everything back on, let me know if you guys need any help to remove the interior panel ... I did it once before so it took me about an hour or 2 to remove all the panel this time.
Pm me for the contact info
Old May 3, 2011 | 01:34 PM
Anpaul's Avatar
Looks like I'll be doing this at some point in the future. My soft top cut wide open sometime last night.
I haven't had a chance to look at the car yet, but I was told that there isn't any interior damage. When I first heard, I was fully expecting my seats and stereo to be gone.
Any advice?
Old May 3, 2011 | 02:01 PM
saaboteur's Avatar
Just take your time, and make sure you have enough and proper sized rivets. If you are converting to glass window from plastic window, make sure you also have some nylon straps to properly modify the frame bars - otherwise there are interference issues.
Some of the DIYs talk about removing the roll hoop covers - I never did that and had no trouble. The DIYs also talk about how difficult it is to get at the plastic cover behind the rear seats. It's not half as bad as they make it out to be, unless, of course, you're a 350lbs Hawaiian shaped dude, then you might have difficulty pretzeling into position to remove the fasteners. But if you were a 350 lbs Hawaiian shaped dude, you probably wouldn't drive an S2000 either...
Old May 4, 2011 | 07:28 AM
~blacks2k~'s Avatar
Any advice?
Get a hardtop then you never have to worry.
