Prairie Redliners Canadian Prairie Provinces. Alberta, Saskatchewan, Manitoba
Painted Calipers
Old Mar 26, 2005 | 05:00 PM
doodlebug's Avatar
Default Painted Calipers
Has anyone local painted their calipers (or purchased coloured ones)? I am mildly interested in red calipers...they would look good with the new wheels. I have seen some pics posted on other forums...doesn't look like too much work (for someone who knows what they are doing).
Old Mar 26, 2005 | 06:34 PM
Woodson's Avatar
I love coloured calipers, but I think it's a little ghetto on 'plain' brakes.
Old Mar 26, 2005 | 06:56 PM
doodlebug's Avatar
Is there a brake upgrade that will fit behind the oem wheels?
Old Mar 27, 2005 | 09:28 AM
LUV2REV's Avatar
You should be able to get aftermarket drilled/slotted rotor's equal in size to the OEM rotor's that will give you the look you desire. You would then just paint your calipers to get the full effect. If you want an aftermarket "bigger" brake upgrade package which would include larger rotors/calipers (Wilwood, Stoptech, Brembo, etc.) you may run into problems with caliper clearance with the 17" wheel and certainly will with the 16's. The aftermarket packages tend to be very expensive as well.
Old Mar 27, 2005 | 07:58 PM
koala's Avatar
The smallest wilwood's fit the stock wheels with a 3 to 5 mm spacer as far as I know.
Jeremy Clarkson
Apr 1, 2014 04:53 PM
modMonkey
Feb 11, 2008 05:18 PM
s2kpnoy
Jun 5, 2007 08:21 AM
bubbs
Apr 15, 2006 05:45 AM
bjohnston
Jul 19, 2002 12:13 PM
