Prairie Redliners Canadian Prairie Provinces. Alberta, Saskatchewan, Manitoba
Project: Fix and Upgrade
Old Aug 31, 2005 | 07:31 AM
  #21
4doorj's Avatar
^a performance upgrade which is worth it is the final drive gear
Old Aug 31, 2005 | 08:50 AM
  #22
Radorotrex's Avatar
what kind of performance would i see for a 4.57 gear? who in town can do the install?
Old Aug 31, 2005 | 10:04 AM
  #23
Seks's Avatar
Originally Posted by Radorotrex,Aug 31 2005, 08:11 AM
but probably need to get some plastic sheets to cover the headrest area. gonna do that tonight. the installation was
You can get the MajorHavoc headrest plastic insert..
Old Aug 31, 2005 | 10:53 AM
  #24
Radorotrex's Avatar
i was thinking about buying those but i sure it would be pretty easy to make yourself. just need to get a thin sheet of plastic and cu it myself.
Old Aug 31, 2005 | 12:45 PM
  #25
koala's Avatar
you're going to gain a 10.3% advantage in mechanical torque by doing the 4.57 gear swap. (4.1 / 4.57 * 100)
Old Sep 6, 2005 | 06:51 AM
  #26
Radorotrex's Avatar
finished the head rest wind blockers. helps a little bit but well worth it considering how much it ended up costing me. 4bucks for a sheet of clear plastic at pms hobby. also was able to make a extra set for my buddy's S.
very easy to do. just pull off the cover piece on the head rest and use that as a template to trace on the plastic sheet. you'll have to cut it a little bit larger so that it wont fall out of the hole.
Old Oct 13, 2005 | 02:47 PM
  #27
Radorotrex's Avatar
i should be getting my car back tommorow. got some pics of the new fender installed. anyone know how to post pics?
Old Oct 13, 2005 | 04:48 PM
  #28
4doorj's Avatar
cant wait to see pics...
to post pics u have to host it from somewhere... and copy the address
and use the [img][/img] tags
just put it between the squared brackets
Old Oct 14, 2005 | 06:53 AM
  #29
Radorotrex's Avatar
can anyone host for me?
Old Oct 14, 2005 | 07:36 AM
  #30
4doorj's Avatar
i probably could.... i dont have the address saved at work... so it will have to wait till i get home or something... make sure its jpeg and u have resized it so its not huge !
