Prairie Redliners Canadian Prairie Provinces. Alberta, Saskatchewan, Manitoba
rag top cleaner
Old Apr 20, 2005 | 06:34 PM
4doorj's Avatar
Default rag top cleaner
i know i can look in the wash section...
but i wanna know what you guys use in calgary? and where did u get it? is it easy to use?
last time i checked at my canadian tire i couldnt find anything for the rag top
my top is really grey compared to the car
thanks for the help
Old Apr 20, 2005 | 07:01 PM
koala's Avatar
303 convertible top cleaner, and 303 vinyl protectant... i think they're at zellers. They'll make it look pretty damn black afterwards
Old Apr 20, 2005 | 07:37 PM
4doorj's Avatar
sweet thanks koala... im heading to zellers tomorow
is it easy to use?
Old Apr 20, 2005 | 07:57 PM
koala's Avatar
Yep... rinse the top down with your hose... spray the cleaner all over liberally, use a clean cotton towel or wash mitt, agitate it nicely, rinse it clean, dry it as best as you can, then follow up with the protectant.
For the protectant I suggest spraying it onto a cotton towel and then wiping the top down with the damp towel. if you spray it directly onto the top, it doesn't go on very evenly!
Old Apr 20, 2005 | 08:00 PM
4doorj's Avatar
did it make a huge difference on yours?
Old Apr 20, 2005 | 08:38 PM
xviper's Avatar
I've been using the 303 the past year or so and it works pretty good. Makes the top look like new. However, before that, I used to use "low gloss" ArmourAll and it worked just as good.
Just remember to apply it with a cloth like Dylan said and NOT too heavy so that it doesn't get "runny" wet. Then leave to top up overnight to let it dry out completely. Do this AFTER you wash the car so that you don't have to wash to car too soon again. This will allow more time for the stuff to dry. Otherwise, some people have noted that if they wash the car before it's dried, it will run all over your car and make a mess. I've never had this problem, so that must be what some guys are doing wrong.
Old Apr 20, 2005 | 10:03 PM
koala's Avatar
huge difference! I used to use it on my '01 all the time. I don't think I've ever used it on my '04 yet... probably should take my hardtop off and clean the soft top some day soon.
Old Apr 21, 2005 | 06:19 AM
4doorj's Avatar
now to fix my next problem.... i used this meguilars plastic polish.... it worked perfectly... it was crisp clear!!! but then i started to use my top, putting it up and down the past week... it looks like there is scuff marks between where the plastic folds..... kinda annoying
Old Apr 21, 2005 | 07:11 AM
xviper's Avatar
Plastic polish be it Maquiar's or something like Plexus can leave a white stain on the black top material. Is this what you see?
Old Apr 21, 2005 | 08:11 AM
4doorj's Avatar
no... a scuff on t he actual plastic window.... like the plastic is scuffing plastic when it folds... maybe i will clear it again... and then put the tint back on
i have to go buy some new tint though...
