Prairie Redliners Canadian Prairie Provinces. Alberta, Saskatchewan, Manitoba
seized lug nut
Old Oct 22, 2006 | 01:24 PM
koala's Avatar
Default seized lug nut
I'm trying to take my volks off for the winter, and I have 1 or more seized nuts... I've bent my socket wrench trying to remove this thing.... and I more than maxed out my 150 ft-lb torque wrench trying to get this one particular nut off.
any ideas? I might just take it to a tire shop, but I'd like to avoid that...
Old Oct 22, 2006 | 03:41 PM
koala's Avatar
Update: Dave is the best, he gave me some suggestions and I managed to get the nuts loose finally.
Suggestion: If you use aluminium lugs, take them off periodically and wipe off all of the corrosion. The metal used for the studs and the metal used for these types of lug nuts are not compatible... I didn't think it would be an issue as last season I changed wheels even later into the year and the nuts came off with ease.
If I still have this car next season I'll be sure to take the nuts off every couple of months to keep up on the corrosion issue.
Old Oct 23, 2006 | 12:17 AM
elusiv's Avatar
Was gonna suggest some Liquid Wrench and putting a 5 foot pipe over the socket wrench, but good to hear you got it off!
Old Oct 23, 2006 | 08:27 AM
koala's Avatar
I woke up today feeling like I was doing squats with 3 plates a side... but yes I got them off
Old Oct 23, 2006 | 12:00 PM
elusiv's Avatar
How did you get it off anyways?
Old Oct 23, 2006 | 02:35 PM
koala's Avatar
I did a couple of things, and I'm not really sure which of these did the job...
1) Some liquid wrench
2) Standing on the wrench while holding onto the fender lip and softtop of the car
3) Slightly tightening a nut and then trying to loosen it again
4) Swore a lot
Old Oct 23, 2006 | 09:05 PM
elusiv's Avatar
I'm sure you felt pretty cool doing that! hahaha.
Oh well, as long as it does the job right?
Old Oct 24, 2006 | 06:07 AM
FormerH22a4's Avatar
1) Some liquid wrench probably was it.
Old Oct 24, 2006 | 10:31 AM
Kremlin's Avatar
Isn't liquid wrench on a lugnut a bad idea? I'd be afraid of them shaking themselves loose after...
I had some badly seized lugs on my Miata about a year ago; Kal Tire couldn't get them off, even. I got them off by putting the torque wrench onto the nut so that you'd push down on the arm to loosen, put a pipe over the handle to extend it out about another two feet, then I made quick, short stomps on the end. Worked like an impact wrench and cracked them all off pretty easy.
Old Oct 24, 2006 | 11:05 AM
koala's Avatar
I'm going to degrease and wash them carefully for storage anyway, so I'm not too worried about it
