S2000 Body and Paint Body kits, paint, ding repair and related discussions
Circle on paint from antenna
Old Jul 3, 2018 | 04:47 PM
silenc3x's Avatar
Default Circle on paint from antenna
Anyone remove their antenna and have a ring like this?
Think I can claybar or polish this away? Or would it require a repaint?
Don't mind the water marks it was raining .
Old Jul 4, 2018 | 04:42 PM
rpg51's Avatar
I think that will come out using common paint correction/scratch removal techniques.
Old Jul 13, 2018 | 11:56 AM
Pinky's Avatar
What did you put in the antenna hole?
Old Jul 13, 2018 | 12:28 PM
PilotmanS2K's Avatar
As RPG51 said, scratch remover and even automotive polish will remove that. Visit any store that carries auto detail supplies and you'll find a bunch of different products. For future reference, the typical rule of thumb is that if you drag your thumbnail over the scratch and you can feel it dig in, it may be too deep to remove with traditional compounding. However, compounding and polishing can remove (or at the very least significantly reduce) most surface scratches, scrapes and scuffs. Let us know how it works out.
Old Jul 13, 2018 | 05:35 PM
TheBasedDoge's Avatar
You may have to wetsand and polish that...
Where did you get that plug? I want one.
Old Jul 18, 2018 | 08:00 AM
Pinky's Avatar
Inquiring minds what to know!
Old Jul 19, 2018 | 05:19 PM
silenc3x's Avatar
sorry guys didnt see this! Thanks for the advice.
I think I could remove it with V36 and V38 from Chemical guys that I already have. Light abrasive polish. I think its just clear coat damage and I can't really feel it with my nail. If that doesn't work I could use a more abrasive compound/polish like v32.
That being said, I am getting a brand new rear OEM bumper in the new few weeks, and theyre doing some paint work so I'm just going to have the antenna hole fully plugged and painted at the same time. The whole panel will be repainted so I'll leave the ring for now.
The antenna cap you are looking for is part number: 82871-671-000
https://www.hondapartsnow.com/genuin...1-671-000.html
https://www.ebay.com/itm/OEM-Honda-9...-/301226308864
Amazon Amazon
It's a 25mm rubber grommet. The antenna is easy to unscrew and remove with the right tools. I bought snap ring pliers on amazon specifically for the job and it was a breeze. Few minutes at most. Then you just unscrew the antenna base through the right side of the trunk. It's bolted to the body.
I was originally hunting for something of a similar size that I could paint, but any antenna delete plug is somewhat bendable like rubber to seal the hole, so you won't be able to paint it. Still, the rubber grommet looks better than the antenna by far.
Old Jul 19, 2018 | 05:27 PM
silenc3x's Avatar
25mm rubber grommet, part number: 82871-671-000. Links in comment above.
Old Jul 20, 2018 | 11:43 AM
Pinky's Avatar
Thanks very much!
You probably can't really PAINT IT like you said.............but you could probably wrap it in vinyl!(wheels turning)
Old Jul 20, 2018 | 11:59 AM
silenc3x's Avatar
Thanks very much!
nice idea, i like that.
If I wasn't just going to get the whole panel painted I would do that. I want that shaved look though.
