Gap under headlights? Easy fix?
I recently purchased my car a few days ago and noticed a gap at the lower section of the drivers side headlight. It's almost as if it's bulging out ever so slightly from the car. Not sure if anyone has experienced this or knows of any easy fix? The driver side looks normal as you can see form the pix below. Any help would be great!
Looking down on drivers side:
Looking down on passenger side:
I have the same problem on my drivers side. I actually hit someone from behind going a couple mph. Bought a new bracket where the bumper is held in. But still getting a gap like yours. Hope you find a solution. So I can fix mine also.
This is kind of a common problem just like the rear bumpers flaring out. Usually due to direct heat (sun) on s certain side, a wreck, or someone getting into the car and not putting it back right.
You can try to loosen up your headlight bolts and see if you can push it flush, that is if your bumper is flush all around except in the headlight section.
Good luck
Good luck
