Headlight Fogging
3M is the company, I'm sure you've hear of them. PPP stands for Paint Protection Film. They are the original "clear bra" makers.
I've had it on for 3 yrs and no fogging at all. It's not specifically approved for it because some headlights get too hot, but for ours it fine. Works great.
Do our headlights yellow after being sanded/buffed? I know some lights have a UV protectant film, and will yellow over time if you sand it off. I don't want to get into a vicious cycle, and would rather live with a foggy light than a yellow one.
You can buy UV coating. They will yellow/oxidize extrememly quickly if not treated, and depending on how much it sits outside.
Clean headlight
Wet sand with 3-4 grit levels (I used 600-800-1500-2000)
Wipe with a pre-kleeno type solution to clean all dust and kill contaminants
Spray UV coating
The UV coating I had needed to be sprayed through a paint gun (I believe it was just a rebranded clear coat), but you can probably get an aerosol based spray.
I didn't get good before pictures, but you can see my after pictures. https://www.s2ki.com/s2000/topic/108...thread-03-gpw/
Clean headlight
Spray UV coating
yes, table yellow and fog. One or the other, or both. That's why you put 3M paint protection film on them.
call a company called start shield solutions in Ontario California. They are one of the main distributors. Have them look up my name, David Crandon. In my account they will have the code for the cut out for the headlight witch they had to do custom. They have said that it's OK for me to let people do this. Then they will send you the film. You can apply it yourself.
Clean headlight
Spray UV coating
Clean headlight
Spray UV coating
