S2000 Body and Paint Body kits, paint, ding repair and related discussions
mounting oem wing?
Old Dec 29, 2011 | 08:52 AM
s2jerris's Avatar
Default mounting oem wing?
I just bought an oem wing which has 2 broken screws on one side, is there a way to fix this so i can mount the wing and not fall off... also where can i get a template for the install?
Old Dec 29, 2011 | 11:16 PM
realblag's Avatar
Which wing is it?
Old Dec 30, 2011 | 08:05 AM
s2jerris's Avatar
Its this one
http://www.handa-accessories.com/S2000/wing.jpg
Old Jan 5, 2012 | 02:17 PM
dfvs2k's Avatar
There is no template, however if you download the instruction for install it will walk you through the steps. I did mine recently and there are two predrill stamp outs in the trunk lid (inside) that are you initial guides. The new spoiler normally come with two o-rings that are sticky (double side) which aids for the drilling of the front two screws. It not that hard if you have the ring markers, but is a scary job when you are drilling your own car. Good luck!!
Old Jan 5, 2012 | 07:09 PM
s2jerris's Avatar
I can probably do that, but what do i do about the broken bolts...
Old Jan 6, 2012 | 05:20 PM
dfvs2k's Avatar
Oh Crap!! broken bolts? it seem that the bolts are integrated into the wing. You may just have to buy a new wing or try to re-install new bolts and find a way to adhere them to the pods with so heavy duty industrial glue. I am not sure, how well it will hold up to the high speeds. Last thing you want to see is your wing flying off the trunk at high speeds.
szkf22c1
Oct 8, 2010 07:37 PM
chinkieboy
May 21, 2009 10:37 PM
ATL_S2K
Feb 12, 2009 05:02 PM
S_special
Jul 9, 2008 09:32 PM
xviper
Oct 23, 2003 12:50 PM
