OEM Trunk Spoiler Install
The first weekend after I bought my S, I ended up behind another Silverstone that had an OEM spoiler and I've wanted one since. I finally got mine last weekend, from Majestic Honda, who seemed to have the best price. All of the OEM spoilers come pre-painted and it was much easier to install than I though it would be.
I did not plan to install the new trunk lid springs that come with the spoiler but it turns out that the new trunk springs DO help with popping the trunk open and holding it open once the spoiler is on. I was able to remove and install the springs with tape-covered channel locks and I'd suggest wearing heavy gloves when placing them, just in case. This is about the hardest part, man this hurt..... https://cimg8.ibsrv.net/gimg/www.s2k...407b2e6e07.jpg But this one hurt even more. Just be sure you center-punch perfectly. Once you drill the two outer holes, which are based on pre-cast marks inside the trunk, you install the spoiler with the two outboard bolts through the trunk. The inboard holes will have 2 double stick doughnut-shaped stickers attached, which will remain on the trunk lid and show you where to drill. The spoiler has two bolts attached to the underside at the outboard edges, and two nuts affixed within the spoiler for the inboard holes. https://cimg9.ibsrv.net/gimg/www.s2k...79f5b5990f.jpg With supplied grommets prior to seating the spoiler. Be sure you get good paint coverage on the freshly drilled metal. https://cimg0.ibsrv.net/gimg/www.s2k...8a0b8da3f6.jpg Fit one side and then flex the spoiler to make the other side "reach" the other hole. https://cimg5.ibsrv.net/gimg/www.s2k...d430fd1941.jpg Its a tight reach to get the middle two bolts tight. https://cimg7.ibsrv.net/gimg/www.s2k...e2901a1219.jpg Torque specs seemed high to me, I tightened the bolts just enough to compress the butyl washers without crushing them. https://cimg6.ibsrv.net/gimg/www.s2k...a47b79a6f2.jpg Done, and damn happy with it! https://cimg9.ibsrv.net/gimg/www.s2k...26fbf7e14c.jpg https://cimg0.ibsrv.net/gimg/www.s2k...56cfa77ed0.jpg ________________________________________ Install instructions here. ________________________________________ |
looks good im debating if iwanna do that spoiler
Nice work! I've always preffered the look of an S2K with a spoiler :thumbup:
you don't have to drill the middle holes. i had mine on with just the outside holes for two years no problem.
You did apply touch up paint to the drilled holes? I hope so. |
[QUOTE=Suzuka_Joe,May 24 2010, 09:05 PM]you don't have to drill the middle holes.
[QUOTE=Vanishing Point,May 25 2010, 09:43 AM]You did apply touch up paint to the drilled holes?
Perfect. Buying my today, and I have been looking for a DIY link. Thanks. Ill post up my pics as well. SilverStone all the way.
Nice work and for the DIY. I prefer to just 3m double side tape.
1 Attachment(s)
Originally Posted by xoz
(Post 21093564)
as mentioned above, i REALLY hope you applied touch up paint to drilled holes too common do I see riced up civics with two lines of rust coming from the spoiler holes Attachment 108259 |
| All times are GMT -8. The time now is 07:29 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
