S2000 Body and Paint Body kits, paint, ding repair and related discussions
Painting ap1 Wheels
Old Oct 17, 2011 | 11:14 AM
OVER 9000!'s Avatar
Default Painting ap1 Wheels
Hi guys, I am rather inexperienced with painting anything and so I was just wondering what the recommended procedure is to get this little project done right. I'm wanting to paint them either matte or semi-gloss black. So what are the steps? Or is there a diy thread that anyone can point me to?
Old Oct 17, 2011 | 11:38 AM
theprophet36's Avatar
Could always Plasti-Dip em!
Old Oct 17, 2011 | 02:32 PM
OVER 9000!'s Avatar
Okay here goes the newb question. What exactly is plasti-dip and can it be applied easier than sanding, priming, clear coating, and spray painting the wheel?
Old Oct 18, 2011 | 02:06 AM
Plasti-Dip is essentially a spray on rubber coating in a can. All you have to do is remove the wheels from the car, clean them really well, mask off the rubber, spray 4-5 coats and enjoy. No sanding, no other prep involved. I have done my emblems and spark plug cover in matte black and they've come out great (have to see how it holds up to the heat on the cover). best part is if you don't like it, mess it up, or just want to change colors.... it peels off! It's rubber, so it doesn't chip either.
The colors are limited and I think you can only do a matte finish, but if you do a search a bunch of guys have used it with good results. I also believe some have used it as a primer and you can put a gloss coat of paint over it. Again, with Plasti as the undercoat it should peel right off. It's about $8-9 a can.
Good luck!
Old Oct 18, 2011 | 03:43 AM
jmaS2knj04's Avatar
From an automotive painter to newbe...
1. Remove wheels from car.
2. Wash with soap n water, let dry. If u have an air compressor, blow dry.
3. Buy a container of wax n grease remover (liquid) and clean very well!! Tires n all!! It will make tape stick to tires ealier!
4. Mask off tires with tape and paper, duct tape and newspaper will work fine.
5. Buy some 600 and 800 grit sandpaper as well as grey/fine scuff pads. Start with the 600 grit paper and start sanding, then 800 grit, then scuff pad. You can sand it without water (dry).
6. Blow off dust and clean very well with the wax remover again.
7. Buy a tack cloth (any hardware store) and wipe all loose particles off.
8. Go to autozone of something and they have a flat black matte finish spray bombs.
9. You'll need to apply a couple of coats! Put the first 2 coats on dry n then start to build up your paint. The use of a heat gun or hair dryer will speed it up! Make sure not to spray to wet or it WILL run!! I would let dry for like 3hrs or so.
10. Untape and bolt on!!!
hope u make out alright!! But u should def sand n paint! I wouldn't just spray without sanding... You need the paint to bind into the scratch. Good luck!!
Old Oct 18, 2011 | 06:09 AM
OVER 9000!'s Avatar
thank you!! You've helped me out a lot! So you wouldn't recommend just plasti-dip? And if I go with your method would I need any spray on primer?
Old Oct 18, 2011 | 10:31 AM
jmaS2knj04's Avatar
Def don't use that stuff!!! And, no, there is no need to prime them... The paint from the factory wheels are a perfect base to work with! Just be careful not to sand through the paint on the wheels. (if you start to see a different color under the paint then STOP sanding.) glad to help a fellow s2k owner out! good luck you'll do fine!
Old Oct 18, 2011 | 11:03 AM
jmaS2knj04's Avatar
Def don't use that stuff!!! And, no, there is no need to prime them... The paint from the factory wheels are a perfect base to work with! Just be careful not to sand through the paint on the wheels. (if you start to see a different color under the paint then STOP sanding.) glad to help a fellow s2k owner out! good luck you'll do fine! Just take your time. Don't rush it n you'll be happy with your end result.
Old Oct 18, 2011 | 12:36 PM
BobbyC's Avatar
plasti-dip from what i gather is ok if you want a temporary paint job as it will eventually look like ass.
the steps above should be pretty good.
im planning on painting my spare set too.
cept, i was planning on just using paint remover to get the clear coat off the wheels.
sand 400-800
primer, paint, clear,
wet sanding in between.
from the research ive done, that should be perfect.
yuning83
Dec 2, 2010 11:07 AM
acus2k
Jun 18, 2010 04:10 PM
josh7owens
Jul 31, 2009 02:58 PM
wills2k106
Apr 28, 2008 06:58 PM
s2000estcst
Sep 14, 2006 09:48 PM
