2006 with Ohlins DFV 10/8 Springs still has too much body roll
#31
Hope your shoulder heels soon
#32
Back again
Rear spring upgrade & FSB re-install.
Any chance of a Bias % of the current install as not the same spring rates front and rear..
Any needs to swap springs front to rear<though this current set up feels very good now and stability is lots better>
<close too OEM 07/ 08 MY Bias> is the hope here ??
600LB rear coil spring <Falkner><because $45 each>
571LB front coil spring<Ohlins>
392 FSB<CR>
311 RSB <Oem 04MY>
25lb lighter on exhaust silencers so rear overhang as using Tanabe G, it effects bias also.but how much ?
would be very helpful if you could help please @Car Analogy
Thankyou
#33
I got this eibach front bar and the 04 rear Bar with the ohlins and some roll center adjusters in the rear, front offset camber joints and its a dream to drive, might get the swift springs you got aswell - let us know how you like them once installed.
Coffee_Lake (02-28-2024)
noodels (06-02-2018)
#35
Square wheel setup? Which setting are you using on the eibach fsb? I plan on running this exact setup, minus the rear RCA/ball joints.
#36
Im running advan gt's 18x10 et40 front and rear with 275/35's and the eibach fsb is in the stiffest hole (the hole for smooth tracks), my car is an ap1
now that ive had a chance to track the car a bit id think (atleast from my testing results) id say the ohlins dfv comes with maybe (what feels like to me) a bit to soft of springs possibly. Id like to try the car with some new springs next track season. just my findings personally tho.
#37
Thanks @ CarAnalogy for posting those different scenarios.
Do you have a link to that Excel spreadsheet? I would love to play out a couple different scenarios with different sway/spring setups.
#38
Hi Everyone,
I am hoping to get some advice about the following:
I have a 2006 with stock sway bars (300 front; 311 rear) and Ohlin DFV Coilovers with 10/8 Springs. I want to reduce body roll some more. I bought a set of the Swift 12lb springs from Patrick at Urge Designs but have not yet installed them.
Would it be better to install the Swift 12lb springs so I would have 12lb front/10 rear OR leave 10/8 current springs and install the bigger CR front sway bar?
Also, even though I have SBG's lowering cups I'm not running my car low to the ground. I used the rear lowering cups to set SBG's recommended preload (from SBG's consulting). So my ride height is actually half an inch higher that stock.
#39
#40
Wait...why'd you buy the cups if you wanted the ride height so tall?
