Sponsored by: Sake Bomb
Alignment Help
Old Jun 2, 2018 | 07:44 PM
jplake's Avatar
Default Alignment Help
I have a MY03 S2000 running a non-staggered 17x9 +45 with 245/40 RE71r’s. Car is lowered on BC DS Series coilovers 12k front / 10k rear. Stock sway bars.
Car is used mostly for street and autocross driving with an occasional track day. I am new to these cars so would appreciate some input on what I should be looking to set my alignment specs to dial it in.
Old Jun 2, 2018 | 09:12 PM
Bullwings's Avatar
-3.0 camber all around.
5.5 to 6.5 degrees of caster (your preference based on "feel" may vary)
0 toe up front
1/8 total rear toe-in if you like a bit more rotation and turn-in, 3/16ths if you're more of a neutral "calm" driver
Old Jun 3, 2018 | 11:36 AM
jplake's Avatar
I assume the 1/8” total rear toe will make the car more tail happy?
Old Jun 3, 2018 | 01:42 PM
Orleansjunky's Avatar
no. if anything the rear is following the front. but some one may know better then I.
Old Jun 3, 2018 | 02:35 PM
Bullwings's Avatar
Not necessarily. I find that too much toe-in makes the car less progressive and more snappy.
While the initial feeling of having a lot more toe-in will make the car feel stable, as the car approaches the limit I find that as you unload the suspension, the break away is snappier and less progressive if you have too much toe-in. The sweet spot for me is around 1/8th to 3/16th total (or 0.20 - 0.25 degrees). I prefer the quicker turn-in, bite, and predictability of less toe-in.
I have an AP2, so your results may vary since the AP1 has more dynamic toe characteristics with loading/unloading the suspension. The AP2 rear suspension geometry was revised to reduce AP1's more dynamic characteristics.
bronxbomber252
May 13, 2009 03:09 PM
memorandum4121
Feb 6, 2008 05:44 AM
teamking
Mar 25, 2006 01:34 PM
onani
Nov 23, 2005 03:23 PM
xda2000
Nov 29, 2004 03:31 PM
