Sponsored by: Sake Bomb
Alignment question
Old Jul 4, 2017 | 09:42 AM
C4vettrn's Avatar
Default Alignment question
Getting alignment tomorrow and want some input. Car is a MY 02 with stiffest factory sway bar front and softest factory rear i.e. MY 99/06. Still running oem coil overs. Tire are staggered 17" 215/45 and 245/40. Street driven 90%, auto-x 10%. I want to improve on current alignment without hurting street manners. Below is what shop showed current alignment as, thanks.
Old Jul 4, 2017 | 03:47 PM
Bruunz's Avatar
What do you actually want to improve?
Just judging from the sheet you should set a baseline with a relative stock setting. Which you seem to be a bit off from.
I'd start with the UK alignment. Off the top of my head i think its (hopefully someone can confirm if i have it right)
F Camber -1
F Toe 0
F Caster (just ask for max caster - you should get about 6 or more)
R Camber -1.5 (or -2????)
R Toe In Total 0.4
I cant remember if toe in is negative or positive so just make sure its Toe in
Old Jul 4, 2017 | 04:28 PM
C4vettrn's Avatar
So on the rear ( toe in ) I'm looking for 0.2* each side ?
Old Jul 5, 2017 | 03:40 PM
Bruunz's Avatar
So i actually googled it and its (from robrobinette) and yes 0.2 for each side. Conversion is a little tricky as 0.4 total is in minutes.
UK Specs (AP1 only)
Front Caster 6º 45' (+ 0.75º over US Spec)
Front Camber -1º (+ 0.5º)
Front Total Toe 0º (no change)
Rear Camber -2º (+ 0.5º)
Rear Total Toe-in 0º 40' (+ 0.036 inch)
Old Jul 5, 2017 | 03:48 PM
Bruunz's Avatar
Please make note that values are in degree / minutes (60 minutes in a degree) - Welcome to the metric world
The other thing to be wary is the skill of the person doing the alignment. Not many cars have adjustable caster and there is a process for adjusting it.
If the shop says they cant adjust one without severly affecting camber then they don't really know what they are doing and i would suggest finding another shop that can.
You should easily get to 6deg of caster with -1 camber at stock height unless you have something bent.
I prefer a lot less toe-in than this (i'm at 0.2 deg total). Start here though and drive the car then come back with impressions.
Old Jul 5, 2017 | 07:23 PM
Singh_snisen's Avatar
For a street car that u like to drive hard sometimes.
fronts:
-1 camber or a little more if u would like
keep caster even at 6 degree or more both sides
0 degree toe up front.
Rear:
-1 camber
7-14 degree toe in each side.
Have fun !
mball19
Apr 27, 2015 08:00 AM
blasphemy101
Jul 12, 2011 09:05 AM
nish
Mar 17, 2006 09:24 AM
Squeezer
Mar 28, 2003 09:32 AM
cdelena
Nov 14, 2000 06:41 AM
