Alignment Settings
Hi,
I just got my car back from the tyre shop and i suspect that the caster setting are way to high. My car is not a daily driver and i intend to do the odd track day. Car is lowered on BC Racing BR coilovers.
Wheel specs: Work vs-ss
F: 18x7.5 +40
R: 18x8.5 +52
Tyres: Kumho XS KU36
F: 225/40/18
R: 245/40/18
Alignment specs:
Rear
L Camber R
-2.3 -2.3
L Toe R
+1 +1
Front
L Camber R
-1 -1
L Toe R
-0.5 -0.4
L Caster R
+11 +11
Should i be concerned with the caster setting? I thought i'd get your advice before taking it back to the tyre shop.
Your input would be much appreciated. i hope i have provided sufficient information above.
Thanks
F: 18x7.5 +40
R: 18x8.5 +52
F: 225/40/18
R: 245/40/18
Alignment specs:
Rear
L Camber R
-2.3 -2.3
L Toe R
+1 +1
Front
L Camber R
-1 -1
L Toe R
-0.5 -0.4
L Caster R
+11 +11
Thanks
Hi,
F: 18x7.5 +40
R: 18x8.5 +52
F: 225/40/18
R: 245/40/18
Alignment specs:
Rear
L Camber R
-2.3 -2.3
L Toe R
+1 +1
Front
L Camber R
-1 -1
L Toe R
-0.5 -0.4
L Caster R
+11 +11
Thanks
F: 18x7.5 +40
R: 18x8.5 +52
F: 225/40/18
R: 245/40/18
Alignment specs:
Rear
L Camber R
-2.3 -2.3
L Toe R
+1 +1
Front
L Camber R
-1 -1
L Toe R
-0.5 -0.4
L Caster R
+11 +11
Thanks
Zero toe on front is probably the way to go.
Keeping camber roughly equal front and rear might be less understeery. Your caster is amazing! I think a value around 7 might be more typical
