Alignment Specs
Originally Posted by fernando.' timestamp='1326978808' post='21331430
[quote name='ZDan' timestamp='1326968913' post='21331250']
Track 3-4x a year is for me a good enough argument for negative camber. For street/track compromise, I'd aim for something like 2.5deg all around, 3 in back if you want to maintain the stock rear camber bias.
Zero front toe, 0.2degrees total rear toe (= .087" = 2.2mm total). This rear toe feels a ton better than the stock range (more linear, less twitchy in a straight line over bumps/irregularities/water/etc, better turn-in) and gives MUCH better tire life.
Wouldn't worry about caster much, ~5.5 or so. IMO anything from 5 - 6.5 degrees = fine.
You could go a bit less on camber, depending on how you want to balance camber wear vs. cornering grip. In my experience, ~2-2.5 degrees camber will knock off about 12-15% of tire life. Based on how you want to trade it off, anything from, say, 1.5 negative to 3 negative should be fine for street/track, with front vs. rear set as you prefer for balance.
[/quote]
I'll probably stay on the mild side for camber, don't think I'll need to go too aggressive.
Thanks again!
I"m going non-staggered 17x9 255. Planning on the following:
-1.25 camber front
zero toe
max caster
-2.5 camber rear
.25 toe
With an Eibach front sway bar. Probably Bilstein PSS9s or Fortune 500 coilovers (10k front, 8k rear springs).
What do you guys think?
-1.25 camber front
zero toe
max caster
-2.5 camber rear
.25 toe
Caster will effect how fast the wheels return to centre. Usually set it to 6deg (max setting) and it feels nice.
I think running 255s all around is silly. The steering input will feel sloppy. Max you should go in the front is 235. Honda designed the car to be staggered for a reason but then again what could 10,000 Honda Racing engineers know about designing the S2000 over 10 years?
-1.25 camber front
zero toe
max caster
-2.5 camber rear
.25 toe
-1.25 camber front
zero toe
max caster
-2.5 camber rear
.25 toe
You should really do some more research then....most track guys go non-staggered.
With a stiffer front bar and 25% stiffer front than rear springs, I'd want more front camber. Maybe 2 front, 2.5 rear, or 2.5 all around. But that's me... You can play with the camber to balance the car to your liking.
Originally Posted by JFUSION' timestamp='1327049888' post='21334859
I've never given caster much thought , other than staying within the recommended Honda spec, not sure what benefit it might give on either side of the spec range. ?
