bbk install help
looking for advice on bracket purchase to install porsche 987 cayman calipers i have on my 2001 s2000. car will have mostly track use. just need help on the brackets which seem to be for most of the brembo kits due to the bolt location, dimensions and pictures would be helpful thanks
It's not as easy as just buying a bracket. You will have to have one made because where the caliper is located on each car is not the same. You will likely need custom rotors, lines and it still may not work. You can contact coleman racing as they make custom brake systems and they helped me with my kit that needed custom rotors but the bracket will be difficult. If you can figure out the specs you need their can make it.
