Sponsored by: Sake Bomb
Better upgrade for ap1? Ap2 rear subframe or rear bumpsteer kit
Old Jan 3, 2018 | 12:16 PM
mojo_jojo77777's Avatar
Default Better upgrade for ap1? Ap2 rear subframe or rear bumpsteer kit
Dont believe I've came across this topic while searching, but what are thoughts about this with cost set aside? I know rear bumpsteer kits can be had for over half or 1/3rd price of doing AP2 rear subframe swap. What would be most beneficial in making most difference in correcting bumpsteer and handling?
Old Jan 3, 2018 | 01:23 PM
THMotorsports's Avatar
Former Sponsor
The easy way is to do the rear bumpsteer kit, you won't get nearly as much toe change throughout the stroke as stock. There should be some threads mapping AP2 toe change and AP1 toe change with and without the toe arms.
Old Jan 3, 2018 | 01:36 PM
B serious's Avatar
I went with a subframe.
I'm cautious...and would rather have OEM parts for points/classing at time trial events...and because aftermarket ball joints worry me. Especially ones with a bending load added to them.
After selling my AP1 parts, I was out maybe $200?
I got AP2 UCA's, spindles, rear bar, and subframe. LCAs and toe arms are the samesies.
Old Jan 3, 2018 | 10:10 PM
I'm not worried about points/classing, because I only do HPDE track days just for fun. But I would like to start tweaking the car more to make myself more confident in it. I'm coming up on 235k miles on all original bushings in car, and since I'd have to do some replacing soon, thinking about ideas on which route I will want to take with car suspension setup wise. seems like the aftermarket way is the quick and easy route, but the OEM route seems like it might cure it better
Old Jan 5, 2018 | 06:34 AM
Car Analogy's Avatar
Originally Posted by mojo_jojo77777
...seems like the aftermarket way is the quick and easy route, but the OEM route seems like it might cure it better
Summarizing responses:
Aftermarket toe correction is easier to implement
Initial cost is cheaper with aftermarket, but if you sell off old stuff, subframe isn't all that expensive
Replacing subframe is more work, but likely to be more reliable, and more effective for the desired result (minimize toe change)
If there is ever any damage, its probably easier to find replacement parts for the oem solution
It sounds like replacing subframe is the more bulletproof solution, and only drawback is effort involved.
Old Jan 5, 2018 | 07:02 AM
Former Sponsor
If you're replacing the subframe, now is also a great time to install these rigid subframe collars I make
Old Jan 5, 2018 | 09:17 AM
Former Sponsor
Wow, I just looked up the price on the toe arms, they're dirt cheap. It's almost cheaper to buy another set of arms than it is to buy a used OEM arm. Sheesh.
Old Jan 5, 2018 | 11:06 AM
s2000Junky's Avatar
Megan rear bump steer kit has my vote
Id be interested to see a graph comparison between a proper set up bump steer kit and OEM/Ap2. Id be surprised if there was much difference. Cheap and easy is what I tend to go with if the aftermarket parts are proven, and they are for me in this case.
Old Jan 6, 2018 | 04:45 PM
Bullwings's Avatar
BSK is cheaper and easier; however, i'd consider it a wear and tear item that requires proper maintenance and replacement.
If you have the resources and mechanical know how, i'd do OEM-AP2.
On track failure below from a local that I've tracked with and taken ride-alongs with:
Old Jan 6, 2018 | 10:29 PM
B serious's Avatar
^yup.
