Sponsored by: Sake Bomb
Brake fluid refill inquiry...
Old Dec 7, 2012 | 08:37 PM
Marc G's Avatar
Default Brake fluid refill inquiry...
Hi everyone. So this happened at the track last weekend. Basically the pad was so worn that the piston bent the inside pad and stuck to it...
(yes yes it is my fault... neglect)
As a result it leaked all of the brake fluids (except for maybe whats left in the other pistons and lines etc). As it stands right now i've replaced both front calipers while the rears are still intact...
Should I go through the brake bleeding process still, or just refill, or what should be the process in this scenario?
Old Dec 8, 2012 | 11:39 AM
HvRRZ's Avatar
Probably good a idea to bleed. Get some fresh fluid in there, and get rid of any air that may have gotten into the system.
Old Dec 8, 2012 | 06:38 PM
RedCelica's Avatar
yes, gravity bleed the system.
Old Dec 15, 2012 | 09:27 PM
Marc G's Avatar
Thank you
Multinational
Dec 11, 2021 09:28 AM
Billman250
Jan 22, 2021 03:51 PM
madmaxblaster
17
Nov 13, 2013 10:59 AM
Opie Oils
UK & Ireland Traders Forum
Dec 15, 2010 03:56 AM
just1guy
Apr 20, 2008 11:25 PM
