Bumpsteer
Do research on which kit you want to buy. There are plenty of threads on this forum regarding this topic. I know for a fact that the T1R bsk has failed, and so has the Megan kit. The only bsk I've never heard of failing (doesn't mean it hasn't...) is J's Racing, but it's pricey.
Like I said, you should try and learn how to drive your car without one first
don't waste your money on a BSK lowerring the car will help
The less suspension travel the less toe-change.
I never had a problem with it and I've seen pictures on this site of bumpsteer kits that have broke on track. The way I see it you are more likely to crash from a broken "bumpsteer kit" than actual "bumpsteer".
https://www.s2ki.com/forums/index.php?showtopic=817939
actual figures for you. on an ap1 bumpsteer is very severe. probably less so on ap2. but an adjustable height rear toe arm (bsk) will help either model, but has to be adjusted properly.
personally i had mine adjusted as described in the thread, but didn't post the results yet. but now it's adjusted absolutely perfectly--nearly 0 toe change in rear. i believe the front is setup to toe out under compression and toe in when lifting (corner exit)--i have to check again.
yes, on the street, maybe not an issue as you won't be pulling as high g's, but having perfect suspension geometry is the difference between your $35k car and a $500k supercar.
