Sponsored by: Sake Bomb
Confused If This Sounds Like Wheel Bearing Or Not.
Old Nov 29, 2025 | 08:23 PM
The01S2kGuy's Avatar
Default Confused If This Sounds Like Wheel Bearing Or Not.
My 2001 has been making an odd noise recently, it seems like wheel bearing noise, however it only starts after 30+ mins of driving. Although, it does go away under acceleration. My main question, is there anywhere to buy the hubs+bearings as an assembly, so I do not have to get the bearings pressed in myself?
Video of noise:
Old Nov 30, 2025 | 11:30 AM
Bullwings's Avatar
Sounds like it. This is my wheel bearing failure sounds - very similar.
Old Nov 30, 2025 | 01:30 PM
Jub's Avatar
Jub
Mine wasn't nearly as loud as either of those. What convinced me that my issue was a wheel bearing is that the noise changed significantly under side loading. If you're turning left and right, does the noise change significantly based on the loading of the rear end?
Old Dec 1, 2025 | 02:10 AM
Slowcrash_101's Avatar
If you don't want to press in new wheel bearing and hub, you have to get a new Knuckle assembly, which is a lot of money. It comes with the hub, wheel bearing, and a new lower ball joint. It's not that hard to remove the rear knuckle, a bit tedious, and that axle nut takes either a really strong impact or some serious muscle. There's a lot of DIY videos, just show that to the machine shop. Shouldn't charge you more than $90 to press them in, and that's if they don't like you.
Check the wheel bearing easily by raising the car off the ground, rotate the wheel and feel for any play. A bad wheel bearing will make noise when you spin it, and it'll have play when you rock it back and forth. Bad ball joints can also cause that sound, because if the ball joint has slop in it, it'll make the wheel not track straight and cause tire noise after a while.
Old Dec 1, 2025 | 04:14 PM
Jub's Avatar
Jub
Not here to argue but mine did not make a noise rotating by hand and felt smooth enough. It also did not have play. Just a noise that got worse and worse until I couldn't ignore it anymore and the side to side variance convinced me it was a rear wheel bearing. All quiet after changing them.
Old Jan 7, 2026 | 12:34 PM
vk45de's Avatar
The way to diagnose it is to jack up the car, spin the wheel, and feel the control arm. If the wheel bearing is gone, it'll feel gritty.
S2000.45
Jul 28, 2025 04:56 PM
Shift9303
Mar 28, 2021 05:51 PM
LowMayne
Mar 28, 2017 09:56 AM
j8mie
Apr 20, 2012 11:29 PM
SeaHawk
Feb 18, 2011 08:14 AM
