Sponsored by: Sake Bomb
delete
Old Sep 17, 2012 | 11:43 AM
apme123's Avatar
Default delete
question resolved
Old Sep 17, 2012 | 12:31 PM
MM3Kwolik's Avatar
Posting this in another section isn't going to get you any answers. Just like I said in the Under the Hood forum, nobody is going to be able to DEFINITIVELY tell you what size your springs are. Stop being lazy and measure them yourself. It's impossible to look at a picture and know for sure..... Oh and calling someone "a little girl" won't get you much help on this site from the Members who normally would take time out of their own day to help.....
Old Sep 17, 2012 | 01:46 PM
06Estukay's Avatar
They look like Eibach springs. There should be white markings on it. Find out what the part number is, and you'll be able to find out exactly what you have...
Old Sep 17, 2012 | 04:52 PM
apme123's Avatar
these springs dont have any writing on them or any kind of marking that i can see, ill remove another wheel later see if the other side has any writting.
Old Sep 17, 2012 | 07:44 PM
06Estukay's Avatar
Did you try rotating the spring to have a look on the other side? Should be marked...
Old Sep 18, 2012 | 10:36 PM
faxter18's Avatar
could be ebay
Old Sep 19, 2012 | 06:29 AM
PureFunction's Avatar
could be ground control. colors match on the sleeve.
Old Sep 19, 2012 | 04:29 PM
IntegraR0064's Avatar
If they're really ground control (which they do look like it unless they're some kind of really close copy) then the springs are going to be either 2.5" inner diameter or 2.25", most likely 2.5". Since those are the only two choices you should be able to figure it out pretty easily with a ruler, even with them still on the car.
Best way would be to take some calipers (you can get them for $15 at advance auto), measure the diameter of the wire, multiply it by 2, then measure the outer diameter of the coil and subtract the 2 wire diameters from it to get the inner diameter. As long as you're close you'll know if it's 2.25" or 2.5".
Best thing to try first though is rotating the springs, they should have a part number on the spring.
Mek-Tek
R&C Parts For Sale
Oct 11, 2011 05:46 PM
BrockB
21
Dec 5, 2010 06:06 AM
J.nguyen
May 6, 2008 01:09 PM
JamesB
Jan 14, 2004 10:57 AM
