Sponsored by: Sake Bomb
dot 5.1 longevity
Old Dec 23, 2010 | 05:09 AM
Croc's Avatar
Default dot 5.1 longevity
i'm going to install Challenge SS lines that i got - so i thought perhaps to use dot 5.1 or Motul RBF600.
my concern is its longevity in hot and humid climate (think Florida or 7-8 months similiar to NYC's summer).
i drive ~1,000km every month and my car i used mostly on weekends and mostly for spirited driving and sometimes x-cross - so reducing brakes fade feeling is important to me.
but i don't want to replace brake flueid every 3 months....
so what do you think?
will it last a year whithout significant degrading?
Thx,
Gennady
Old Dec 23, 2010 | 04:28 PM
VAD's Avatar
VAD
I'd start out with an inexpensive DOT-4 and see if boiling is an issue on track. If boiling is a problem, you can upgrade to DOT-5.1 without worrying about DOT-4 and 5.1 mixing together a little.
Spirited driving and the occasional autocross shouldn't necessitate more than an annual flush and bleed in your conditions.
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
Old Dec 24, 2010 | 10:09 PM
Croc's Avatar
i already have dot4 refreshed 6 months ago.
so i understand that dot4 and dot5 absorbe humidity in a similar rate?
so if d0t4 worked OK for me for 1 year than dot5.1 should last the same?
Old Dec 25, 2010 | 03:52 AM
VAD's Avatar
VAD
I think you'll be able to go a year on a fill given your conditions. Here's a cheap way to monitor the health of your fluid.
http://phoenixsystem.com/products_by_type/...strip/index.htm
Old Dec 25, 2010 | 04:41 AM
c32b's Avatar
A brake ducting setup I did gave fade free performance over multiple track sessions over the course of a >1year tracking & daily driving in >90% humidity & high track temperatures.
I hope this article I wrote is helpful
http://www.tractioncircle.com/index.php?op...id=45&Itemid=73
Old Jan 5, 2011 | 10:58 AM
Croc's Avatar
eventually i put Motul RBF600.
pedal feel is light years better !!!!
frankly this also might be related to the way they bled the system - they used some vacuum orerated device which sucks the fluid.
this is instead of usual "mump the pedal" way which i suspect is less reliable.
anyway - i'm extremely happy now - finally S got brakes that it [almost] deserves.
imrovements always are welcome - but now it's really OK.
AZS2KDancer
Nov 30, 2017 08:50 PM
miamirice
Jan 10, 2011 06:37 AM
nse2167
Jan 20, 2010 07:38 PM
riceburners2001
Jan 22, 2006 10:45 AM
124Spider
Aug 6, 2004 08:34 AM
