Just wanted to share with you the new EVS Tuning Offset Camber Joints.
EVS Tuning Offset Camber Joints fits all S2000 model years.
Comes in anodized red forged aluminum 6061 with an engraved EVS Tuning logo.
EVS Tuning Offset Camber Joints provides enough negative front camber by locating the lower ball joint at an eccentric angle from the center. The front camber angle can be adjusted to the stock +3 degree.
Included:
Camber Joints x2
Clip x2
You may reuse the stock bolts. Always check and apply the correct torque. It is recommended that you properly adjust the ride height and alignment.
