Sponsored by: Sake Bomb
front brake pad life
Old Feb 2, 2011 | 03:40 PM
doofus's Avatar
Default front brake pad life
I'm up in the snow up northeast and I just noticed my 08 is swerving left when braking and not braking well when the brakes are cold. My used s2000 had "new" pads installed before I bought it 4000 miles ago and there's about a mm or two of space between the caliper and the disc on the outside. i'm guessing that my pads are shot and that this aint normal brake pad life? only thing i can think of is that the traction control or stability control brake the front wheels or they're adjusted wrong.
at this rate i should buy a whole crate of front pads...
Old Feb 3, 2011 | 08:39 AM
AJ_72's Avatar
My front pads on my '03 lasted more than 50,000 miles. I changed them at 60K even though they showed approx. 50% wear.
I've never tracked my car and drive less aggressive than average. I don't know what's typical of a street only car though.
I'd make sure the rotors aren't warped and then monitor the brakes carefully.
Old Feb 3, 2011 | 08:43 AM
rioyellows2k's Avatar
Brake pad life can vary among pad manufacturers. Some used car dealeships put crap autozone/carquest/o'reilly pads in just whatever works to say "new" and pass safety requirements. You should be able to get 20K miles out of OEM AP2 pads, or 30K~ish out of OEM AP1 Pads.
vteconly
Apr 30, 2013 08:13 PM
dakao
Nov 1, 2012 06:58 AM
Hedropsforglory
Sep 22, 2011 06:57 AM
Valentino007
Aug 13, 2007 12:31 AM
