front rotor cooling
What size is the tube? How's the wheel clearance? does it rub tied to the upper control arm like that? Routed the same on both sides?
Sorry for the 20 questions but I think I'll be making a home depot run to build my own set, might even run one to the caliper to keep it cool. I'm not tracking the car yet but would be a cool project for the winter hibernation period.
My Mech. said it was the best kit he'd ever installed. Here's the info.
Our Super Touring kit is designed for the avid track attendant or dedicated track/race car. The hose has a 600 deg. F temperature rating. You will not melt the hose in this kit, no matter how hot your brakes get.
Competition Brake Cooling Kit Features:
Two (2) - 2" 6061-T6 TIG welded aluminum ducts designed to direct the air to the center of the rotor for the most efficient and effective cooling.
2” flexible hose (10 feet total!) featuring a silicon coated polyester fabric mechanically bonded to an external wire to stand up to the rigors of everyday driving, an operating temperature range from -45 deg. F. to 650 deg. F, and a compression ratio of 6:1.
All necessary mounting hardware and instructions.
