Going out of alignment VERY quickly...
Hello,
I recently picked up an MY01 bone stock with 111k miles. I have been autocrossing the car since I got it a few months ago. I got the UK spec alignment from Firestone, competed in an autocross, and noticed that the car was horribly out of alignment after the event. The steering wheel had to be turned left in order to go straight. So I took it back to Firestone for a warranty alignment, and all 4 wheels were very out of spec... I thought maybe they didn't tighten something enough or something (sorry, im a suspension noob) and I had them re align it. About a week later, its already out of alignment. The steering wheel needs to be turned right to go straight and it sort of wanders a bit now.
My question is: what could make this car go out of alignment so quickly? I can't afford to re-align it every week and I can't afford to be trashing tires so quickly. Is it possible that alignment bolts need to be replaced? Is this a common issue people are having?
Thanks
Thanks
Autoxers usually double to the torque on the alignment bolts because they slip. Request they do that first
Here is a thread i dug up
https://www.s2ki.com/s2000/topic/113...-front-camber/
Your already taking your s2000 to a garbage facility for an alignment on this car, if your going to choose to take it there to begin with, at least get their lifetime alignment so you can keep taking it back for free each week lol
Eager to hear what you find with subframe bolts. Im betting that is the issue. It would totally fit all the facts, and is not all that uncommon for them to become loose.
Be sure to check both front and rear. Subframes.
If it turns out they are loose, align subframes using the subframe to frame holes, then torque them down.
I have had good success with my local Firestone too...
Sent from my SM-G920P using IB AutoGroup
While this is true, the problem is first you have to find a good tech. Then you have to be able to bring it in when that tech is working. Then, the tech will quit and you are back to square one. Done this 3 times.
