Gravity Brake Bleed flow?
I did a coolant and brake fluid replacement a couple of weeks ago. Last done by the dealer 5 years and 20,000 miles ago.
The gravity brake fluid process worked well other than the left rear caliper where it barely dripped for an hour. Other cylinders got several ounces in 15 minutes. Car is braking just fine.
Any way to push/suck more clean fluid in this brake caliper?
-- Chuck
-- Chuck
Use a pressure/vacuum bleeder or get someone to push the brake pedal.
Could be some junk or rust in the bleeder valve that restricts the flow.
5 years in use is a bit to long for brake fluid and it will have degraded a lot during that period.
When I did mine I started with the front right then the left front. Both fronts flowed well. With the left flowing the fastest
The rears were SLOW. I did both at the same time. They were so slow I had no fear of running the master cylinder dry.
Cannot think of a way to speed up the process. Using vacuum devices or two person bleeding speeds the process but you are not gravity bleeding anymore.
I like the firm pedal I get from gravity bleeding.
But it is painfully slow.
The ABS unit has something to do with the speed of the bleed.
Gravity bleeding my 1990 non ABS Miata takes no time at all.
Yeah, it's super duper slow. So much so, that I never wanna gravity bleed again.
I will prolly try those bottles with the built-in check-valve, the next time I need to bleed brakes.
(as I don't like running speed-bleeder valves on the actual brakes (had them in past cars)... just preference, as I like oem, more solid and simpler parts).
Part # YA4000B
You can buy a new one from Snap On (Bluepoint / Mityvac) like I did or pick them up on Ebay for half off. There are generic versions of this, and I have one of those too but it's of lesser quality. I really like the quality of this tool and the customer support guys are great.
Thanks for the recommendation. I'll investigate used (or Harbor Freight). Gravity bleeding my rear brakes too so long I gave up after a couple of hours. Very little drained out. I like the ability of these pumps to suck the old oil out of the brake and clutch reservoirs.
-- Chuck
-- Chuck
I have a motive pressure bleeder I have used on my other cars that works wonderfully. I need to make a cap for the S2k though as the adaptor I have does not fit well and thus will not hold pressure.
For the S2k, I have done it via the brake pedal. Came out nice and firm like every other car I have ever bled brakes on.
