Sponsored by: Sake Bomb
Help with koni coilover install
Old Apr 9, 2012 | 07:40 PM
Ayge's Avatar
Default Help with koni coilover install
I'm in the middle of installing Koni coilovers and I've run into a bit of a snag. I have revalved double adjustable Koni sports with Koni threaded sleeves and hyperco springs. Front springs are 900# 8"x2.5", rear springs are 750# 8"x2.5". The coilovers are on the car with the spring perches in the lowest possible position and the ride height is 14.5" hub to fender. I preloaded the control arm bolts at each corner according to helm manual. What am I missing?
Old Apr 9, 2012 | 08:29 PM
macr88's Avatar
Do you have helper or tender springs?
Old Apr 9, 2012 | 09:06 PM
Ayge's Avatar
No helper springs.
Old Apr 9, 2012 | 09:57 PM
macr88's Avatar
Are the sleeves as low as they can go on the bodies?
Old Apr 10, 2012 | 01:53 AM
robinson's Avatar
You are missing the problem, which I can't tell from reading this post.
Old Apr 10, 2012 | 04:30 AM
Ayge's Avatar
I just looked at one of the front shocks, it looks like there's 2 snap ring grooves below the bottom of the threaded sleeve. I'm guessing the problem is the sleeve is up too high and needs to be dropped to the bottom position. Thanks.
Old Apr 10, 2012 | 07:52 AM
macr88's Avatar
Yup, let me know how it sits after
Old Apr 20, 2012 | 05:28 AM
Ayge's Avatar
After lowering the sleeves and bottoming out the perches, I'm down to 13". Was hoping for 12.5", but it is what it is. Thanks again for the help.
Old Apr 20, 2012 | 07:06 AM
RedCelica's Avatar
OT: How much did the revalve cost you?
Old Apr 20, 2012 | 09:02 AM
06Estukay's Avatar
Try running shorter springs. At those spring rates, you could easily go down to a 6" spring. Try a 7" spring first and go from there.
