Sponsored by: Sake Bomb
help me for coilover
Old Dec 29, 2013 | 04:00 AM
kasmar0909's Avatar
Default help me for coilover
hi guys, i recently replace the rim from stk to CE28
From 16inch to 17ich.
The problem is i was driving with 16inch with coilover fitted, i was safisfied with stiffness and lowness. but when i put 17inch rims, obviously suspension had been rasied up and looks not aggressive and stiff enough.
so i lowered the coilover(it does not touch the fender- 10mm gap) however at cornering, it rubbing, probably spring is not stiff enough
therefore i decided to change the spring pre-load. Am i right to go to change the spring pre-load to fix the problem or do i have to change to stiffer spring???
Old Dec 29, 2013 | 06:23 AM
s2ka's Avatar
What size wheel and tire? Wheel offset? What kind of coilovers?
Old Dec 29, 2013 | 05:55 PM
kasmar0909's Avatar
17x7.5 50 225/45/17 for front
17x9 63 245/40/17 for rear
The coilover brand is HKS
I have no idea for spring rate because the previous owner fitted it
Old Dec 31, 2013 | 08:10 PM
s2ka's Avatar
I have the exact same Volks on my car running Bilstein PSS9 lowered to about 1 finger gap all around. With the stock fender liner and no tab modification you will rub sometimes if you run anything wider than the stock Bridgestone RE050 fronts. Even my 215/45/17 RE11 fronts will rub a little because they are wider than the OEM tires. So 222/45/17 will rub unless you make changes.
I wouldn't recommend changing spring rates unless you want a stiffer ride.
Try modifying the fender liner and tab first, see where it's rubbing and melt or cut the plastic liner. Raise the car a little next, add camber if needed. I'm not a fan of rolling fenders but if done by someone with a lot of experience I've seen some good results.
theS2K
Aug 23, 2015 08:58 PM
hamy
Jul 30, 2011 08:45 AM
S2000_FUN
Nov 18, 2010 04:15 PM
Nick.
May 23, 2010 07:05 PM
KLN
Sep 30, 2003 10:58 PM
