Help me PLEASE ... with Alignment
hi everybody i have a 2005 gpw s2000 with tein coilovers dunlop direzza tires , front cusco sway bar EDFC , i just alignment with uk SPEC i have the rear tires new and the front ones like 60 % of life. the four tires are at 30 PSI but NOW i feel the steeting more nimble or faster so much that when i change of line i feel steering much faster than before but more nervous. i feel the car nervous when changing lines after 60 or 80 km , i read that to much caster make the steering slower i was having 7 of caster and now 6 45 maybe i need to put 7 again.
Maybe i need more caster ....!!!!
UK Alignment Specs
front castor 6.45
front camber -1.0
front toe 0.0
rear camber -2.0 NOTE i put 1.6 of camber
rear toe 0.20 total 0.40
Front Caster 6o45" = 6.75°
Front Camber -1.0°
Front Toe 0.0°
Rear Camber -2.0°
Rear Toe 0°20" = +0.16°
Total Toe 0°40" = +0.32°
UK Alignment Specs
front castor 6.45
front camber -1.0
front toe 0.0
Front Camber -1.0°
Front Toe 0.0°
Rear Camber -2.0°
the car was having 0.10 from the rear left and 0.60 from the right of toe in now is corrected to 0.40 , my car when i turn the steering to fast it UNDERSTEERS also understeers on turns...
i just readed that more caster makes steering slower and more precise maybe i need more camber and caster in the front
http://desmond.image...jpg&res=landing
Why are you running 30 psi in your tires? Shouldn't it be about 32 psi?...
On a side note, if the car feels like it is understeering, then it is because you have less toe, but on the same token, what I read on your first post is that you stated you felt like the car's response to input was faster and more nimble, which is the exact opposite of understeering...please elaborate which statement is correct and which one I am misunderstanding.
