how do u minimize rear end movement when power shifting
I'm not to sure on what it's called, but I recently lowered my S on fortune auto 500''s and I'm constantly changing settings to get it comfortable but I've noticed since I lowered the car the rear end kinda feels like it wants to kick out when I'm driving fast especially from 2nd to 3rd gear. What can I do to make this go away or minimize the movement ??
Do you mean while cornering or driving in a straight line?
If its moving side to side between shifts in a straight line then its probably your alignment. If youve been adjusting the height and havent had an alignment after then your toe will be off. |
Maybe the increased camber makes for smaller contact patch and makes the tires easier to spin when you're powerslammin them gears with the homies.
I'm guessing that the car has not been aligned after lowering it either? |
smooth is fast. Be easier on your shifts. You'll actually be faster that way. "power shifting" the car throws the weight balance off, increases likelihood of drivetrain malfunction, and is just all around a poor idea.
What are your alignment specs? |
To be honest I haven't got an alignment yet, I'm waiting on my wheels and tires to come in to do that so I can also set the camber for wheel fitment
Originally Posted by ChrisG_ap1
(Post 23917390)
You will also need to recenter all those adjustments you made to the suspension, because with the alignment being all out of whack and you trying to adjust for that, correcting the alignment you will also now have to recorrect all the coilover changes you did. Google "UK s2000 alignment" Those are the settings you'll want. 0 toe up front and I'd say 1/16 toe in the rear. |
Lol ok redcelica u can put ur dictionary away now. As I said I'm waiting to get my wheels and tires to do my alignment I have to run some negative camber because I'm going with an aggressive wheel/tire set up. What u said makes absolutely no sense, no offense
Most here don't need a dictionary to spell common words associated with cars. Also, what he said makes perfect sense.
Ok I'm not gonna get into it with anyone I just wanted to make sure there wasn't anything outside of getting an alignment that could cause the issue I'm having. But when someone says u don't adjust camber for wheel fitment and gives me a whole speech on camber that's when I step away from the whole thing. Thank you everyone for your input
He was just shooting some knowledge your way.
What I took from your message is that A) your car must be very fast and you love power shifting in a straight line and B) you likely slammed your car and are putting low offset wheels on it that will need excessive camber. Just get an alignment once you have your wheels and tires and check back to see if the car is still doing the same thing. Good luck :thumbup: |
