Sponsored by: Sake Bomb
How to rebuild front calipers?
Old Jun 13, 2017 | 10:59 AM
hornyhonda's Avatar
Default How to rebuild front calipers?
I have an s2000 thats been stood for a while and as a result all the calipers are siezed. Does anyone have any advice on how to rebuild the front calipers using the rebuild kits on ebay? Or a link to a how to guide?
Thankyou for your help
Old Jun 13, 2017 | 03:37 PM
Car Analogy's Avatar
Personally I would buy remanufactured calipers from a quality supplier that only used oem seals and components. Otherwise I would buy oem rebuild kit, not fleabay for something this critical, on a car like this.
To rebuild: (admittedly this is not S specific, rather its how I've done on other cars)
Remove caliper
Use compressed air into brake line connection to pop piston out (make sure to catch it in a rag so it doesn't get damaged)
Remove old seal from caliper, being careful not to scratch bore
Remove seal from piston, being careful not to damage piston
Thoroughly clean caliper and piston
Put new seals on
Lube seals and piston and bore with brake fluid
Push piston back into bore
Its a simple job, but sometimes piston doesn't want to come out. Sometimes piston is corroded and must be replaced.
Once on a decades seized motorcycle caliper I had to heat it tremendously to get piston out. But bore and piston were both still useable (it was a Harley, so not a performance application by any stretch).
OldDogmeat
Jan 26, 2012 10:34 PM
buzzin hornet
Oct 6, 2011 07:46 AM
Boost-Me
Jul 31, 2011 06:45 PM
vtecrx
Jun 27, 2011 12:34 PM
RobJ1
Feb 25, 2008 11:12 AM
