Sponsored by: Sake Bomb
Leveling the ride on my new Ohlins?
Old Jun 23, 2025 | 04:36 PM
WVCR-V's Avatar
Default Leveling the ride on my new Ohlins?
So I finally splurged for ohlins after running HKS 20spec for a few years. It was worth it! I could ramble on about why but for now I’m trying to dial in the ride height before I get an alignment. I can only afford about a 15-20 mm drop because of my driveway but that’s all I really want anyway. So I’m measuring from center hub to fender like I have before with my old coilovers but I realize my garage floor isn’t perfect. I mean it’s pretty close but it’s off level by about 1/8” from drive side to passenger. So should I just set all of my coilovers at a specific height per each axle. The recommended thread length is 104mm front and 22 rear I believe for a 25 mm drop. So for my milder drop I’d go something like 108 front and 28 rear. Should I quit trying to get exact same measurements from side to side and just set the shock body lengths equal? Am I overthinking it? Also how much can I adjust before needing to restock the bushings again? How much rake should I have for general street/ mountain driving?
Thanks
Old Jun 23, 2025 | 05:40 PM
noodels's Avatar
Set my shock lengths equal per axel.
Old Jun 23, 2025 | 06:02 PM
WVCR-V's Avatar
Im leaning toward this. I’ve jacked the car up and taken off the wheels several times already to guess and check and measure. Only to realize there are variations in my floor. I’m about over it. lol.
Old Jun 24, 2025 | 04:53 PM
Car Analogy's Avatar
You're clocking all the bushings when you change ride height, right?
Old Jun 25, 2025 | 03:41 AM
WVCR-V's Avatar
I finalized the ride height last night. I ended up setting the shocks equally from left to right. About 8 mm higher the Ohlins default settings for 25mm drop. This should net me a 17-18mm drop which is perfect for me. I had already clocked the bushings but then last night made some 3-4 mm adjustments. Do I need to clock again?
Old Jun 26, 2025 | 10:09 AM
Slight changes to ride height don't need to be reclocked.
However, if you're checking height one side vs other, looking for exact symmetry, not clocking could confuse results. If you're doing that, I'd reclock.
In fact, I'd leave everything loose, set onto ground, make my slight adjustments here, there, until I liked how it sat, liked symmetry. THEN I'd clock bushings.
Also, secondary purpose of setting coilover ride height is corner weighting. Getting each corner weight same left vs right, and desired balance front vs rear. Very helpful for track.
But thing is, doing this always results in different ride height each corner. Point is, symmetry is aesthetic only. Getting perfect symmetry doesn't make it handle better.
Dizings2k
Aug 6, 2018 05:49 AM
mndthegap1
28
Apr 7, 2014 03:21 AM
itr.#1446
Nov 14, 2012 09:11 AM
chillout18
Apr 1, 2008 10:12 AM
kevsS2
Oct 8, 2004 01:51 PM
