Lowering a CR? Sacrilegious?
What are your thoughts on putting springs on a CR? Now I am talking about a high quality, mild drop, spring like the swift.
I have always had good experiences with Swift springs in the past, on other cars, when my goals decided against coilovers.
I would think with the swifts mild drop, obtaining factory alignment specs wouldn't be an issue.
Thoughts?
Thoughts?
Originally Posted by RedCelica,Nov 11 2010, 07:29 AM
coilovers only...don't blasphemy the CR by just dropping it on springs alone.
2 options are:
Leave it alone
Swift springs
Like I said I have used the swifts in the past, when I didn't want coilovers with good results, and no diminished handling, but am also not opposed to just leaving it.
Those are pretty much the only spring I would even remotely consider.
why not just get ground control sleeves. 400lb front 350lb rear. those are pretty much CR rates (392, 342) and you can adjust it to whatever height you want. keep the drop mild so you dont lose too much in suspension geometry and you should be good.
The Swift SpecR would be the perfect mild upgrade to a CR. Given the CR's more aggressive valving. And the specR spring rates, I think it would be perfect. The SpecR's are 7.5k fr and 7k rear, just slightly stiffer than the CR.
