Sponsored by: Sake Bomb
Installed Koni Yellows/CR springs Uneven Height
Old 04-10-2015, 09:32 AM
Inspired's Avatar
Default Installed Koni Yellows/CR springs Uneven Height
I recently installed Koni Yellow shocks with OEM CR springs on a MY05. After the install, I noticed that the front end sits just slightly higher than the rear.
I will upload some pics later today of the height difference. Would pre-loading the bushings incorrectly cause this? Though, I am sure that I pre-loaded them right.
Any ideas?
Old 04-10-2015, 10:34 AM
s2000ellier's Avatar
did you put the fronts on a different perch and than the rears?
Old 04-10-2015, 03:33 PM
Inspired's Avatar
I set all four to the second lowest perch on the Konis.
Old 04-10-2015, 05:40 PM
frei's Avatar
Mine is the same, my front sits higher on my koni yellows with swift springs.
Old 04-11-2015, 07:28 PM
Inspired's Avatar
Hmm...very strange indeed.
Old 04-12-2015, 12:33 PM
frei's Avatar
Could be because the spring rate is stiffer in the front that the rear..
Old 04-14-2015, 07:53 AM
Back S2k's Avatar
Have you realized that our rear wheel arches sit lower than the front? An even drop will always have the rear sitting lower than the front.
Old 04-15-2015, 08:36 AM
Car Analogy's Avatar
Received 1,316 Likes on 994 Posts
Also those who have switched to CR springs and shocks report that nose sits visually higher afterwards.
So not surprising to see same result with CR springs on some other shock.
Old 04-15-2015, 11:48 AM
Banned
jr94513's Avatar
Throw 00 ap1 rear springs in the rear, stiffer spring rate and should give it a slight rake
Old 04-15-2015, 07:19 PM
Inspired's Avatar
I actually didn't know that. Thanks for clarifying.
Well, isn't that interesting!
I can live with the slightly elevated front end if that's how they were designed.
Thanks for the tip.
Quick Reply: Installed Koni Yellows/CR springs Uneven Height
