Sponsored by: Sake Bomb
Need thoughts on my final alignment specs
Old Oct 4, 2011 | 03:15 PM
FearlessFife's Avatar
Default Need thoughts on my final alignment specs
Got an alignment today guys.
The problem is the shop I took it to could not get the camber to even up left and right. Their computer would not cooperate and allow them to even things up.
Front right: -1.4
Front left: -1.7
Rear right: -2.3
Rear left: -2.7
I run a more aggressive setup to maximize the suspension for street and track use.
Thoughts on the .3 difference from side to side? Should I try and get that evened up, or let it be? Keep in mind I only put about 2500 or so miles on a year.
FYI, the toe settings front and rear were optimal.
Old Oct 4, 2011 | 03:20 PM
importkid's Avatar
If the tech could get it within .3 of being round then they shouldn't have slacked. It's not gonna be a huge issue with the mileage you do but I do about 15k a year and I wouldn't have it. Do you have the print out? What's thrust angle if you do. Does the car pull left?
Old Oct 4, 2011 | 03:25 PM
No pulling to the left at all.
Old Oct 4, 2011 | 09:51 PM
Croc's Avatar
their computer is their problem.
i would redo it.
maybe at another shop.
BTW - i like more camber at front than rear.
i have staggered wheel setup and it works beatifully.
Old Oct 5, 2011 | 04:55 AM
i would redo it.
There lies the problem. I really don't want to have to pay for another alignment. I guess I don't understand why there isn't some sort of override for their computer that allows them to meet customer requested alignment specs?
I run a lot more in the rear as well. Previous settings for camber: FR: -1.3, FL: -1.3. RR: -2.3, RL: -2.4. Makes a HUGE difference just to set the suspension to a little more aggressive than stock.
Cyrax
Jan 24, 2015 05:09 PM
slatkimalict
May 20, 2010 07:49 AM
x s2k x
Jul 20, 2006 02:07 PM
teamking
Mar 25, 2006 01:34 PM
TWOK
Nov 8, 2000 10:46 PM
