Sponsored by: Sake Bomb
OEM Equivalent Caliper Slide Pin Boots
Old Jan 17, 2023 | 10:07 PM
PuristDriver's Avatar
Default OEM Equivalent Caliper Slide Pin Boots
The slide pin boots on the rear brakes of my AP1 are shot. It looks like Honda only sells these as part of a caliper seals set with grease that retails for $45. I tried our local O'Reillys for an aftermarket set, but it seems like the diameter is a bit too small as I had to push the pin in really hard although it does move well once in. Ideally, I find a properly sized third-party set for a reasonable price. Let me know what you have found that worked well. RockAuto has a few different brand options, but I'm worried that their diameter will be too small as well based on Amazon reviews.
Old Jan 19, 2023 | 05:37 AM
Car Analogy's Avatar
I mean, if boot worn out maybe seals are too. Why not bust the budget and do a full rebuild?
If no funds for that now, look for a cheap aftermarket rebuild kit that includes boots, then just use the boots. The seals (that you won't use) are what separates a good rebuild kit from a crappy one.
Old Jul 10, 2025 | 11:56 AM
Ljkrush's Avatar
I know this is an old thread but I'm still interested in any experience with aftermarket slide pin boots for the S2000. I just went through 3 different front sets from Rabestos, Advance Auto and one off brand loand none of them fit. The outside diameter of the boots don't fit the caliper bracket bore. If forced in the pin can't be inserted. Had similar issues with rear ones but not as bad. Tight fit but pin will slide. So...anyone have hands on experience with finding a brand that fits or is OEM the only option?
Old Jul 10, 2025 | 09:47 PM
thoiboi's Avatar
https://www.rockauto.com/en/catalog/...+bushing,11515 couple cheap options on Rock Auto to explore
Old Jul 11, 2025 | 02:45 AM
Ljkrush's Avatar
Thanks...I got the Raybestos ones from Rock Auto and they don't fit. Trying to narrow down options to one that fits before going through the whole list. Hoping someone out there can vouch for a set that fits properly.
apsdsmracer
Jun 8, 2017 10:59 AM
midnightmethane
Mar 14, 2006 06:48 AM
Mr. Francesco
Apr 21, 2005 06:11 AM
Amuse Boy
Jul 22, 2004 04:24 PM
