Official Springs Thread
I don't think the spring rates changed in 06-07, they just added VSA and a few extra braces to the chassis. Someone can check the part numbers to be sure.
OEM:
00-01 Fr: 218(3.9) - Rr: 291(5.2)
02-03 Fr: 240(4.3) - Rr: 230(4.1)*
04-07 Fr: 256(4.57) - Rr: 207(3.7)*
08-up Fr: 274(4.89) - Rr: 225(4.0)*
08CR Fr: 375(6.7) - Rr: 264(4.71)*
*Estimates based on published % changes from Honda.
2004 info: http://www.hondanews.com/search/release/15...ng+rate&s=honda
2008 info: http://www.hondanews.com/search/rele...=s2000&s=honda
OEM:
[QUOTE=s2ka,Nov 29 2007, 11:21 PM] I don't think the spring rates changed in 06-07, they just added VSA and a few extra braces to the chassis. Someone can check the part numbers to be sure.
OEM:
00-01
OEM:
00-01
Originally Posted by Hockey,Nov 27 2007, 11:27 PM
The Bilstein PSS9 is a full coilover......this is about springs.
The spring on the PSS9 acts on the suspension in the same manner as any of the others mentioned. The stock shocks are the same coilover design, the PSS9 simply has the extra features of adjustable damping and adjustable height. The helper springs (in general) are designed to keep the main spring in place under full suspension droop and are (usually) fully compressed when the car is resting on the ground, essentially becoming a solid spacer in normal operation.
Interesting thread. Nice work
Originally Posted by Hockey,Nov 30 2007, 08:29 AM
Where are you getting your numbers? I've been digging through Honda Website articles but all they give is % changes from the previous model years. I've done the math to verify, but if the starting spring rate is not correct (04-07 or example) then the rest of the numbers that follow will be off too.
-Hockey
-Hockey
im looking for a good 1.5 drop all the way around.....and tein , h&r, espelir all show a 1.5 in drop but everyone on the forums this and honda tech are showing only a 1in drop ....and its not worth it for me to buy a coilover set up and drop it cause if i got lower than 1.5 i wont be able to pull into my drive plz give suggestion
You can trust those numbers.
Also remember that if you choose Koni's to replace the OEM struts, you have two choices for perches.....OEM height or an additional .5" so you can combine a drop from a spring and an additional .5" if thats what you want.
-Hockey
-Hockey
thanks new shocks are next on the list and i didnt know about the perches thanks for the info
