Sponsored by: Sake Bomb
quick alignment Q
Old Apr 23, 2011 | 09:01 PM
NFR_AP2's Avatar
Default quick alignment Q
here are my specs after the alignment was done
FL - Camber: -2.5 Caster: 6.2 Toe: 0.01
FR - Camber: -2.6 Caster: 6.2 Toe: 0.05
RL - Camber: -4.0 Toe: 0.11
RR - Camber: -4.0 Toe: 0.10
now the only problem im having is if i let go of the wheel the car will slowly drift right, should i be worried? psi was checked and is the same on all 4 tires
Old Apr 24, 2011 | 10:42 AM
Croc's Avatar
you're numbers look OK.
it shouldn't drift.
i would let them recheck it again.
Old Apr 24, 2011 | 10:46 AM
bmyers4321's Avatar
possible drifting due to road crown?
Old Apr 24, 2011 | 11:38 AM
raneyboo's Avatar
Check your tire tread.
Old Apr 24, 2011 | 11:59 AM
NFR_AP2's Avatar
Tires are brand new direzza z1 star specs
Old Apr 24, 2011 | 12:01 PM
NFR_AP2's Avatar
And I've tried it on different roads....its not an immediate pull but after a few seconds after i let go of the wheel it'll start going right
Old Apr 24, 2011 | 01:01 PM
Mr.Luder's Avatar
By looking at the numbers, it should drive straight. It doesn't matter if the tires are new, they can still cause pulling or drifting. If the tires are not directional, try swaping from right to left and left to right. Also, check your tire pressures and see if they are even all around.
rpmgem
Feb 21, 2018 11:55 AM
davidc1
Oct 21, 2011 10:13 AM
Bronxbomber9009
May 7, 2009 01:25 PM
ChineseDelivery
Jan 10, 2009 10:22 PM
s2addict
Oct 8, 2005 09:36 PM
