Sponsored by: Sake Bomb
Rear Brake problem
Old Jul 18, 2011 | 10:44 PM
Reapur's Avatar
Default Rear Brake problem
Hey guys,
Just did rear brakes on the S, and I've noticed a strange occurrence. Both sides suffer from the same thing, the pad is only making contact with 3/4 of the rotor surface. I can tell this because there is rust forming on the rotors friction surface close to the rotors hat. I stripped the rear brakes today to re-do them and wire brushed all the rust down on the carriers, made sure the pins were not mismatched (smooth pin in the top notched pin in the bottom) and after driving and bedding in they STILL are not applying pressure down on the entire surface. You can easily see that the pad is indeed passing over the entire surface but not making contact when you apply the brakes.
Has anyone out there encountered this and found a solution? Does the cross pattern in the piston have to line up a certain way at all? I'll try to get some photos of the rear brakes up asap.
Old Jul 21, 2011 | 06:54 AM
viets2000's Avatar
did you get new rotors? or get them turned? They may have been wearing irregularly with your old pads.
Old Jul 21, 2011 | 06:58 AM
Reapur's Avatar
New rotors were installed
Old Apr 14, 2014 | 04:01 PM
Josue's2k's Avatar
Have you figured out what was the problem to your rear breaks? I have the same issue with my s2k an it's buggin me I need to fix it
Old Apr 14, 2014 | 07:16 PM
andy_intel's Avatar
I've had a similar issue for a while now, with slightly uneven contact on the rotors and some extra temp generated on one side. This has not changed through replacing pads, calipers and rotors, as well as cleaning of the slide pins.
I did have some success swapping the carriers from side to side, so in my case I think the problem either lays with the carriers or the pins. May or may not help in your case but it's easy to try.
Old Apr 14, 2014 | 10:59 PM
MMisencik157's Avatar
Make sure the grooves on the piston are lined up with the nubs on the backplate of the pad (the one of the grooves has to be perfectly vertical). If they aren't then the top of the pad will be the only thing to make contact with the rotor until the pad wears down further.
Old Apr 23, 2014 | 12:03 PM
Back S2k's Avatar
^x2 very common for the diy'r to forget and just throw the fresh pads in without aligning the piston.
tragicv
Oct 5, 2013 10:42 PM
wickedwiggles
Mar 25, 2011 12:16 PM
vtec9
Dec 17, 2009 11:21 AM
dirtypwntang
Apr 30, 2008 06:29 PM
cvedral
Apr 6, 2007 04:09 PM
