Sponsored by: Sake Bomb
Rear Subframe Drop
Old Oct 5, 2019 | 12:58 AM
chippydave's Avatar
Default Rear Subframe Drop
Hi, I'm dealing with the rear end and rear wheel arch rust over this winter. I'm just wondering roughly how much time/hassle it is to drop out the rear subframe?
Old Oct 5, 2019 | 04:22 AM
Orjinal's Avatar
Half a day on your back. Should be less if you have a lift.
Old Oct 5, 2019 | 04:59 AM
clubhopper's Avatar
Not long or hard at all. I’ve done this a few times on my garage floor.
-disconnect brake line
-disconnect strut at the bottom
-disconnect parking brake support bolts
-disconnect caliper and leave attached to parking brake
-pull subframe bolts with jack underneath diff
-drop it like it’s hot
Pro tip some people think by taking the rotors off and other things will help lighten the load. But it’s false. The more weight you have on the ends stabilize the subframe when you bring it down with a jack. And it’s also less work.
gzob@GearTech
Mar 6, 2023 09:49 AM
Curated Content Editor
Feb 27, 2019 11:05 AM
treimche
Feb 2, 2019 05:04 AM
K_iju
Nov 12, 2018 10:36 AM
anorexicpoodle
Apr 2, 2018 11:10 PM
