Sponsored by: Sake Bomb
removing wilwoods
Old Feb 13, 2011 | 01:41 PM
20002point2l's Avatar
Default removing wilwoods
today i tried removing one of my wilwood brakes (Front) in preparation to install a stock caliper and rotor. i realized that the holes on the caliper do not line up on mounting area. The car came with the wilwoods so i think im missing a part, kind of what the wilwoods have to make them adapt onto the car. Can anybody direct me to the part i need, i tried a search and did not yield any results.
Thanks
Steve
Old Feb 13, 2011 | 04:31 PM
JunD's Avatar
http://www.hondaautomotiveparts.com/auto/j...ry5=FRONT+BRAKE
Old Feb 13, 2011 | 05:20 PM
i looked there, but i cannot see the part i need.. something not adding up here
Old Feb 15, 2011 | 12:42 PM
the distance between the bolt holes on the caliper are 1" closer together then on the spindle... what am i missing?
Old Feb 15, 2011 | 02:40 PM
BrakeExpert's Avatar
Are you sure you have the right caliper? Do these calipers have a separate mounting bracket? A picture might help, but this also might be the wrong bracket or caliper for your car.
Old Feb 16, 2011 | 12:40 PM
i bought them off a member on here, they are supposely stock ap2 calipers but they they are not fitting on my ap1
i will try to take some pics so you see what im getting at
Old Feb 16, 2011 | 02:53 PM
Duke Togo's Avatar
it sounds like you haven't removed the willwood adapter bracket for the calipers yet.
Old Feb 17, 2011 | 11:20 PM
Thats possible. A picture will clear all this up. The stock AP2 front calipers are going to have two 'tabs' on the bracket with threaded holes that use the OEM 17mm head flange bolts.
Steve P
Oct 11, 2013 08:28 AM
sunman
Mar 4, 2012 08:34 PM
clarkster009
Jan 26, 2012 07:24 AM
moonliver
Jul 6, 2010 05:27 PM
mic_crispy
Oct 12, 2005 07:43 AM
