Sponsored by: Sake Bomb
S2000
Old Nov 11, 2012 | 10:51 AM
dsthez's Avatar
Yeah so the control arm bushings were unloaded when I removed them so I would think they don't need to be pre loaded when tightening them. I don't even know if there pre loaded at the factory really can a machine get in there with the wheel in place? I know if you tighten the bolt and then drop the car the bushing could have like a tension build up against the arm. But dosent the arm move up and down around the bolts freely anyways.
Old Nov 11, 2012 | 12:42 PM
Reapur's Avatar
Dude you use a jack to preload the control arm with the wheel off.
The car should be on jack stands. If you don't know what you're doing take it to a shop to have it done right.
If you insist in doing it your self then buy a helms manual and follow the procedure. You can also search using google, there are tons of videos on how to install coils onto an s2000. The forms are not a place to be spoon fed info use some initiative to figure stuff out.
Old Nov 11, 2012 | 02:54 PM
dsthez's Avatar
OK I checked it out looks like I can actually reach under neath the car to tighten them down so I can loosen them wish the wheel off then lower the car then tighten them down right? The lower bolts were already done like this... sounds fine right
Old Nov 11, 2012 | 04:21 PM
dsthez's Avatar
Alright I did it ill test drive and report back thank you
Old Nov 11, 2012 | 05:28 PM
dsthez's Avatar
OK feels the same. my end opinion pre load your suspension for the bushings sake but it dose not affect the bride or ride height. Thank you
Old Nov 11, 2012 | 06:48 PM
realblag's Avatar
Get an alignment and your problems will go away.
Old Nov 11, 2012 | 10:01 PM
Reapur's Avatar
You clearly have no idea what the hell you're doing. Stop messing with stuff, the lower bolts are the camber adjustments. The bolts you need to torque while preloading the suspension are the UPPER control arms.
GOOGLE IT
Old Nov 12, 2012 | 07:44 AM
dsthez's Avatar
That's what I meant the two upper control arm bolts and the lower shock mount bolt have now all been lossened and retightened while the car has been on all 4 tires. Done deal
Old Nov 12, 2012 | 01:09 PM
Reapur's Avatar
OK go get an alignment and corner balance. This is required in any coil over installation, stop trying to cut corners.
Old Nov 12, 2012 | 03:26 PM
dsthez's Avatar
What is corner balancing evening the cars weight by the ride height? Don't you have to be in the drivers seat to get it done?
