Sponsored by: Sake Bomb
S2000 higher on one side
Old Nov 16, 2013 | 02:15 PM
PrettyBoyS2k's Avatar
Default S2000 higher on one side
I have a 2004 Honda S2000 , ans I had one of my shocks replaced in the rear it was the rear passenger side. I was detailing my car, and noticed that passenger side is higher. I had Honda dealership install that shock, the rest of the shocks have roughly 30k miles. Would replacing that one new shock cause the car to become higher on that side?? Thank you guys I am new to the forum but this is my second s2000!!
Old Nov 16, 2013 | 02:23 PM
waleed786's Avatar
It can take a day or two for new shocks to settle in. Has it been longer than that? Are you sure the pavement was level? How much of a difference is there?
Old Nov 16, 2013 | 02:33 PM
It has been about a week already. You can deff see it in the rear well and the driver side looks lower due to the passenger side being higher. You can see the difference at any level pavement esp here in FL all is flat. I would say a good 1/3 inch maybe 1/4 and it happened after installing that 1 new shock
Old Nov 16, 2013 | 03:16 PM
Rays S2k's Avatar
Is the spring sitting correctly
Old Nov 16, 2013 | 03:17 PM
I have not gone under to check but I will check that out asap as well
Old Nov 16, 2013 | 03:24 PM
Rays S2k's Avatar
it should look like this
Old Nov 16, 2013 | 04:39 PM
Okay I will check, but do you think that a new shock would cause that to happened or is that out of the question and it has to be something else
Old Nov 16, 2013 | 04:40 PM
Rays S2k's Avatar
Something else
Old Nov 16, 2013 | 04:53 PM
Thanks I will check in the AM when sun is out I appreciate your help so far
Old Nov 18, 2013 | 10:03 AM
iamxpl's Avatar
was the suspension pre loaded ?
